keribarker
#1 Posted : Thursday, April 9, 2009 3:29:48 PM(UTC)
keribarker
My oven was working fine yesterday and today I turned the oven on and the lights come on saying it is preheating and the element does not heat up. HELP!
misterfixall
#2 Posted : Thursday, April 9, 2009 5:55:22 PM(UTC)
misterfixall
you have to have your bake element checked , you would need a multimeter unless element is obviosly damaged
#3 Posted : Friday, April 10, 2009 4:16:16 AM(UTC)
Replacement parts for TAP TEF351EWB | AppliancePartsPros.com
Here is a tech sheet
ftp://ftp.electrolux-na.com/Pr...pringfield/316441731.pdf
Tech sheet seems to indicate that the bake and broil alternate getting power when in bake mode.
Try broil and see if the broil element heats up.
If no
Check that the L2 wire from the control board to the elements is OK, as it is common to both elements.
Try clean as this is bake only element.
Also you did not say if the surface elements are OK, if not it is a different kettle of fish.
