amichael39
#1 Posted : Friday, October 19, 2012 5:25:46 AM(UTC)
amichael39
FGMO205KFA Frigidaire Built-In Microwave
Replaced Magnatron, then Transformer, then Capacitor Assy - per AppliancePartsPros and still no heat.
Simon / APP Team
#2 Posted : Friday, October 19, 2012 9:14:09 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Please provide complete model number and detailed problem description.
Simon.
amichael39
#3 Posted : Friday, October 19, 2012 10:11:37 AM(UTC)
amichael39
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Simon.
Frigidaire Built-in Microwave - Model # FGMO205KFA
Everything works - except no heat.
Replaced magnatron ((AP4433505), then transformer (AP4434118), then capacitor assy (AP4299471) - per AppliancePartsPros sales dept.
Still no heat.
Transformer does get warm on top after 2 minute cycle trying to test heat water.
Sales dept suggested contacting tech in forum for help.
Simon / APP Team
#4 Posted : Friday, October 19, 2012 1:32:18 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Disconnect the connector from the PRIMARY winding of the hi-voltage transformer.
Using the multimeter check if there is 120VAC across this contacts when the m/w is started.
If the correct voltage is present and you replaced transformer, capacitor and magnetron - check the diod and all wiring according the diagram.
Post the results.
Simon.
amichael39
#5 Posted : Friday, October 19, 2012 8:11:18 PM(UTC)
amichael39
works now - thanks - love you guys
Simon / APP Team
#6 Posted : Monday, October 22, 2012 7:24:16 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
What was the problem?
Simon.
Guest (6)
