2 Pages<12
mtnbiker3000
#11 Posted : Thursday, October 18, 2012 1:32:00 PM(UTC)
mtnbiker3000
Well, not sure if this is correct, but the larger washer seems to fit perfectly at the joining points between the upper and lower agitator. Is this correct?
UserPostedImage
Also, does anything need greasing upon re-assembly??
mtnbiker3000
#12 Posted : Friday, October 19, 2012 6:59:17 AM(UTC)
mtnbiker3000
OK, got it sorted out! Looks like the TWO washers on the left of photo 1 used to be ONE washer. Over time, that washer broke into two pieces... Need a new washer :D
2 Pages<12
