DKB
#1 Posted : Wednesday, October 17, 2012 6:08:23 AM(UTC)
DKB
Recently unit has apparently been dispensing too much rinse aid. Near end of cycle unit sounds as if it is barely moving any water and when door is opened a large amount of bubbles are in rinse water. There is an adjustment inside the rinse dispenser cap and it it turned to the lowest position possible. Have not changed detergent or rinse aid brands. This problem does not exist until the end of cycle but is present regardless of the cycle selected rather than the rinse only cycle of course.
#2 Posted : Wednesday, October 17, 2012 3:38:55 PM(UTC)
The solution is to replace the soap and rinse aid dispenser.
- The dispenser Part number: 99003317
DKB
#3 Posted : Tuesday, October 23, 2012 2:00:13 PM(UTC)
DKB
Thanks Gene!
#4 Posted : Tuesday, October 23, 2012 4:33:47 PM(UTC)
