2 Pages12>
mtnbiker3000
#1 Posted : Tuesday, October 16, 2012 10:17:12 AM(UTC)
mtnbiker3000
So, the other day I noticed my clothes were still soaked when the washer was done. After a little exploring, I noticed it would not spin in any setting. Didn't check to see if it was agitating properly (probably should have checked that too before disassemble :o).
Upon pulling out the motor, I notice the coupler had the teeth sheared off of the motor end. I am assuming this is the problem. Have a new coupler on the way.
The only other issue I am concerned about at this point, is that when I had the machine laid over on it's back, the tranny leaked about 3, maybe 4 ounces of gear oil. I really don't want to buy a bottle or take the tranny out if I don't need to. My question is, is there still enough oil in the tranny? Or do I need to add a few more ounces back in? It looks like the only way to do that is pulling the tranny apart, which I don't want to do... I read somewhere that there is between 12 and 15 ounces in there when full. Will the small amount I lost be missed??????
Simon / APP Team
#2 Posted : Tuesday, October 16, 2012 2:17:44 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
With that amount of oil missing the transmission life span will be shorter.
How much shorter???...
Simon.
mtnbiker3000
#3 Posted : Tuesday, October 16, 2012 3:38:05 PM(UTC)
mtnbiker3000
Well, if it goes 2 or 3 more years I would be elated!!! BTW - I have some 75w90 that I used in the diffs of my Subaru. Is this stuff OK, or should it be a straight 60 or 90? Also, how do you know if it is "detergent free?"
Simon / APP Team
#4 Posted : Tuesday, October 16, 2012 4:28:12 PM(UTC)
Simon / APP Team
Groups: APP Team
Sorry, this is beyond my expertise.
Simon.
#5 Posted : Wednesday, October 17, 2012 1:45:03 AM(UTC)
Did the oil come out the top by the spindle, or out the side seal where the coupler goes?
mtnbiker3000
#6 Posted : Wednesday, October 17, 2012 7:08:51 AM(UTC)
mtnbiker3000
Haven't looked that far into it. It only leaked when it was laid over on the back. Once I stood it back up, no oil... I assume it came from the overflow hole??
#7 Posted : Wednesday, October 17, 2012 12:12:15 PM(UTC)
Your tranny is probably ok asuming the clutch is not oil soaked. I never lay these washers down, too many bad things could happen like oil leaks and skateplate moving out of place.
mtnbiker3000
#8 Posted : Wednesday, October 17, 2012 1:38:00 PM(UTC)
mtnbiker3000
New to this... What is the skate plate??
#9 Posted : Thursday, October 18, 2012 1:00:36 AM(UTC)
The movable, triangular plate under the tub.
mtnbiker3000
#10 Posted : Thursday, October 18, 2012 8:08:04 AM(UTC)
mtnbiker3000
I have rebuilt a couple of dryers, but this is my first washer.
Lesson 1 - don't lay completely over ;-)
So, I am going to assume the tranny will be fine missing a few ounces of oil. Not going to pull it apart unless absolutely necessary.
I do have a question about the agitator bolt and rubber washer that I pulled out. When I took it out, there were two rubber washers on it. One small, beveled washer that fits snug on the threads of the bolt. And another wider, flatter washer that almost pulls over the top of the bolt head (doesn't seem to fit right) - Left and center of pic.
UserPostedImage
When I bolt it back down, the bigger washer doesn't seem to seat right, and if I don't hold it in place with a screwdriver, it will twist and pop out over the top of the bolt. Even when it stays on, it doesn't look like it would properly seal anything.
I bought a new flat washer from Lowe's (on the far right of photo) that fits nicely under the head of the bolt like it seems it should work better.
Why are there two rubber washers on one bolt? I inherited this washer from a family member, but I don't think anyone has ever pulled the agitator bolt before, so I believe it is stock…
Again, the two washers on the left were on the bolt when I took it out of the agitator assembly. Is this correct? Why?
2 Pages12>
