vgranada
#1 Posted : Tuesday, April 7, 2009 6:40:33 AM(UTC)
vgranada
I purchased a used Amana gas dryer. After installing the dryer, it ran fine for 3 loads and then proceeded to run all night on the auto dry cycle. I pulled the front cover and found that the igniter will glow but it appears no gas is getting through. I pulled the regulator unit and inspected the screen thinking that some dirt may have clogged the orifice. The burner area was pretty dirty so I blew it out and vaccuumed the unit. Still no ignition. What would be my next step in the diagnosis of the problem? Any help would be greatly appreciated!
vgranada
#2 Posted : Thursday, April 9, 2009 6:09:43 AM(UTC)
vgranada
After reading some of the other threads with similar problems, and talking to a tech., I replaced the solenoids on the gas valve and dryer now runs fine.
Amana gas dryer won't ignite (Dryer Repair)
by JJim Keenan 12/29/2008 3:58:39 PM(UTC)
