Katzelff
#1 Posted : Tuesday, October 9, 2012 12:19:44 PM(UTC)
Katzelff
My lower arm won't spin and I've taken the sump assembly apart. Looks like the check valve is not spinning from upper to lower spray arms? I rotated it by hand to the lower arms and it now works the lower only. Even when I start washer on upper only setting. I figure it's the motor since everything is clean and rotates fine. I found part #4681ed3001d as the motor. What else should I change out with it since I will have to remove the dishwasher? Any help would be great.
Simon / APP Team
#2 Posted : Tuesday, October 9, 2012 1:04:17 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check the continuity of the motor winding, check if it' getting the 120VBAC from the control board.
If there is voltage - replace the motor.
Simon.
Katzelff
#3 Posted : Tuesday, October 9, 2012 1:14:46 PM(UTC)
Katzelff
It has voyage. I may have got it wet during another repair? I ordered the motor, packing, and a new check valve. That should fix it I think? Thanks for the reply
Simon / APP Team
#4 Posted : Tuesday, October 9, 2012 4:26:31 PM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Post the results.
Simon.
