Lonestar_5293692
#1 Posted : Wednesday, October 3, 2012 12:32:12 PM(UTC)
Lonestar_5293692
My kenmore gas dryer start working perfectly ... Heat is nice and even and there is no noise or any thing but after a period of 15 to 20 minutes heat goes of and the cycle ends with a cold and damped cloths ... I already change the fuse and termistors and thermostats located in the back of the dryer and also clean all ducts from any dirt and now looks clean like brand new .... If I wait another 20 minutes and start it again it works again for the same length of time but shuts the heat again .... What should I check now so it could be fix ....? tNX
Simon / APP Team
#2 Posted : Wednesday, October 3, 2012 2:45:54 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Does the dryer continue running with out heat or it's stops all together?
Please provide the model number.
Simon.
Lonestar_5293692
#3 Posted : Wednesday, October 3, 2012 3:04:54 PM(UTC)
Lonestar_5293692
The dryer keeps spinning like nothing happened but blowing cool air into the cloths ... It did this before I replaced all thermostats and heat fuse but when I check this items all where working good when tested but because I have some doubts I try to play safe by replacing them all but once the new ones where in place it continue to do the same ... I start a dry cycle machine works perfect heat is nice and warm as used to be but after 15-20 minutes shuts heat off and continue doing the job but without heat until the end of the cycle ...
Simon / APP Team
#4 Posted : Wednesday, October 3, 2012 3:15:13 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You need to replace the control coils kit. I'll trade the model number for the part number you need.
Simon.
Lonestar_5293692
#5 Posted : Wednesday, October 3, 2012 3:38:06 PM(UTC)
Lonestar_5293692
Thank you ... Where can I get the model number ? Because I only see that machine is a Kenmore 80 series in the front of it ...
Simon / APP Team
#6 Posted : Wednesday, October 3, 2012 4:02:46 PM(UTC)
Simon / APP Team
Groups: APP Team
Open the door, the tag is right there on the frame.
Simon.
Lonestar_5293692
#7 Posted : Wednesday, October 3, 2012 4:38:40 PM(UTC)
Lonestar_5293692
Is kenmore mod 110.72822101 ....
Lonestar_5293692
#8 Posted : Wednesday, October 3, 2012 4:41:11 PM(UTC)
Lonestar_5293692
It's Mod 110.72822101
Simon / APP Team
#9 Posted : Thursday, October 4, 2012 11:14:35 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Here is the coil kit Part number: 279834
Part number: 279834
Good luck.
Simon.
Guest (6)
