3 Pages<123
kambozn
#21 Posted : Wednesday, October 3, 2012 7:38:43 AM(UTC)
kambozn
Hello Denman,
I have some problem as other. Water do not drain completely. I already did basic troubleshooting like checking for clog. I would suspect a drain flapper, but I would like to get a seconds opinion from specialist.
Could you let me know if flapper should close all the way or only partially (about 3/4)....
MED5870.pdf (187kb) downloaded 14 time(s).
Tech Sheet - W10143265A - WED9600TW0 steam dryer.pdf (573kb) downloaded 82 time(s).
LER4634.pdf (126kb) downloaded 3 time(s).
Kamil
kambozn attached the following image(s):
#22 Posted : Thursday, October 4, 2012 6:05:09 AM(UTC)
I am not 100% sure but it looks like it should close further.
I would remove the solenoid and try the flapper without it.
Also check if it is slipping on the shaft.
Guest
#23 Posted : Wednesday, October 11, 2023 5:29:38 PM(UTC)
Guest
Rank: Guest
United States
Drain solenoid for a dishwasher frigidaire part number a model number ffcd 2418uv2a
3 Pages<123
