ninjak
#1 Posted : Tuesday, October 2, 2012 4:10:54 PM(UTC)
ninjak
Water was coming from under the fridge/freezer (side by side) yesterday so I took off the kickplate to take a look. It looked like the housing was dripping and it had been 18 months since a filter change, so I pulled the filter and place to replace it tomorrow, or possibly replace the housing if that doesn't fix the issue.
I've had the water line to the fridge off for the last 24 hours, however the drain pan seems to fill back up again and is not evaporating... shouldn't it be evaporating while the kick plate is off and there's no filter or filter housing attached? Both water lines are sitting in the drain pan (but again, water line is off)...
The freezer drain is clean, no ice forming, and freezer continues to work...
Help??!!!
ninjak
#2 Posted : Tuesday, October 2, 2012 4:57:35 PM(UTC)
ninjak
Sorry, this is wrong subject area... not sure how it ended up Oven Repair. Will repost in fridge.
Waterline off, Drain Pan Not Evaporating... (Refrigerator & Freezer Repair)
by ninjak 10/2/2012 4:58:35 PM(UTC)
