MThack
#1 Posted: : Tuesday, October 2, 2012 11:21:36 AM(UTC)
MThack
You have been a member since:: 10/2/2012(UTC)
While baking, heard a loud noise from another room. When I came back, the control panel was blank and the breaker had flipped. When I reset the breaker, the range top works, but the control panel is blank. The elements look fine. Electric oven. Ideas?
Simon / APP Team
#2 Posted : Tuesday, October 2, 2012 12:18:12 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check if you are getting 240VAC to the clock L1 - L2in.
If the correct voltage is present - replace the clock
Part number: 316207529
You may need the overlay too.
Here are the breakdown diagrams and Replacement parts for Frigidaire FEF380MXDCA Frigidaire/electric Range | AppliancePartsPros.com
Post the results.
Simon.
