nmckaskle
#1 Posted : Friday, September 28, 2012 5:34:58 PM(UTC)
nmckaskle
washer agitates but will not spin on final cycle. sounds like it is spinning but the tub is not moving. Do i need motor coupling?
dro53
#2 Posted : Monday, October 1, 2012 11:45:39 AM(UTC)
dro53
Hi:
My Whirlpool washer LSN2000LW1 started having a problem with the spin cycle. It would go through the wash cycle and rinse cycle but sometimes at the end of the wash, the clothes are still wet. If the basket was turned manually, something catches and the spin cycle would then work. At other times, the spin cycle would work by itself.
Based upon the recommendation of one of the technicians at Appliancepartspro.com, the clutch assembly was just changed today. I am happy to report that the washer is spinning again. We had tried changing the motor coupling but this did not solve the problem. I hope this information is helpful to you.
Washer Agitates but Won't Spin, Drum Dropped (Washer Repair)
by dagwinn 8/17/2017 4:47:57 PM(UTC)
whirlpool washer agitates but won't spin (Washer Repair)
by vinzant15 2/7/2015 12:16:09 AM(UTC)
GE washer agitates but won't spin (Washer Repair)
by nicolle_m 5/17/2012 5:57:01 PM(UTC)
GE Washer agitates but won't spin (Washer Repair)
by splitune 11/25/2011 1:26:23 PM(UTC)
by Bab 2/17/2009 7:49:43 AM(UTC)
Kitchen Aid Washer Agitates But Won't Spin (Washer Repair)
by leroypg 10/16/2007 8:31:06 AM(UTC)
washer agitates but won't spin` (Washer Repair)
by mls6089 10/12/2007 7:34:53 AM(UTC)
