My Hotpoint dishwasher Model HDA150X-66AW is leaking water from the bottom of the motor and dripping off the solonoid also. I purchased a seal kit, but I would like some instructions about using it, especially as to whether or not I need to pull the dishwasher out to repair it or if I can do it from the inside. Thank You
:confused: Originally Posted by: Beacon18  My Hotpoint dishwasher Model HDA150X-66AW is leaking water from the bottom of the motor and dripping off the solonoid also. I purchased a seal kit, but I would like some instructions about using it, especially as to whether or not I need to pull the dishwasher out to repair it or if I can do it from the inside. Thank You
