The exhaust vent switch on my Jenn-Air Electric Grill/stove (model C221) went bad the other day (appeard to simply melt). I plan on replacing the switch, but while I can understand why the exhaust fan wont work (the switch wont even move), I dont understand why none of the burners work either? The 'red light' comes on when I turn one of the knobs, but the coils wont heat. Is there some sort of 'breaker' switch that maybe got tripped? Or wont the coils work without a functioning exhaust?
Any help is appreciated.
Groups: APP Team
Hi. Here is the fan switch Part number: 12001130
But it's no longer available. You need to reset the circuit breaker then the burners will work. Simon.
Thanks Simon - I'll reset the breaker and thanks for the part number. I found this on ******** - http://www.********.com/itm/120...&hash=item4ab435674f Do you think it will be an decent replacement? Or anywhere else where I could find a replacement? Thanks Pete Originally Posted by: Simon / APP Team  Hi. Here is the fan switch Part number: 12001130
Groups: APP Team
Hi.
If the part you found crosses over to the original part number then use it.
Simon.
