I bought a replacement infinite switch for my Jenn-Air range which is for the right side 3000 watt dual burner. Unfortunately it has to be modified because the original part is no longer made. The old switch has a different harness which is connected to fan as well.
The new switch is coming with the installation instructions. If there are no instructions then contact the company where you ordered it from.
Originally Posted by: Gene  The new switch is coming with the installation instructions. If there are no instructions then contact the company where you ordered it from.
Gene. I got it from AppliancePartsPros.com aren't you affiliated with them? I thought this is where I could get the instructions?
I'm just a volunteer on this forum and I'm not affiliated with Appliance Parts Pros. You have to call their customer service.
