gkacsandi
#1 Posted : Wednesday, September 26, 2012 12:29:44 PM(UTC)
gkacsandi
My dryer runs, but has no heat. The breakers weren't tripped, but I reset them. There is 240V across the main power wires. Both the high and low limit thermostats have 120V at each wire and 0 ohms across the terminals for each thermostat. The heating element doesn't appear to be physically damaged. I'm out of guesses. :confused:
Any suggestions from anyone?
#2 Posted : Thursday, September 27, 2012 3:26:23 AM(UTC)
Replacement parts for Whirlpool IED4400SQ0 29"ELECTRIC DRYER | AppliancePartsPros.com
[COLOR="Blue"]There is 240V across the main power wires[/COLOR]
I am assuming that tis was checked at the terminal strip in the unit.
[COLOR="Blue"]
Both the high and low limit thermostats have 120V at each wire and 0 ohms across the terminals for each thermostat.[/COLOR]
I am not sure what you are calling the low limit?
[COLOR="Blue"]
The heating element doesn't appear to be physically damaged.[/COLOR]
It is best to actually measure the heating coil.
Unplug the unit and set it to mid-cycle heated timed dry then attach one meter lead to L1 and leave it there. Then work your way back through the heater circuit. Everything should be 0 ohms till you get to the heating coil then one side of the coil will be 0 ohms and the other 8 to 12 ohms.
If all OK then you know that either you have a bad wire or a problem with the motor's centrifugal switch.
File Attachment(s):
IED4400.pdf (191kb) downloaded 38 time(s).
gkacsandi
#3 Posted : Saturday, September 29, 2012 10:19:46 AM(UTC)
gkacsandi
Sorry, not 'low limit' but thermal cut off and high limit both have 120 V and 0 ohms. Also, I'm not sure which wire in the standard 3-wire grey cable is L1 or the black one? Someone also mentioned to me about a heater switch on the motor. Could this be the centrifugal switch? Or possibly a problem w/ the timer? I checked the cycling thermostat and is 0 ohms across the larger terminals and about 8 across the smaller terminals. Is that good?
#4 Posted : Sunday, September 30, 2012 1:29:01 AM(UTC)
[COLOR="Blue"]Also, I'm not sure which wire in the standard 3-wire grey cable is L1 or the black one?[/COLOR]
Just measure them back from the terminal strip.
[COLOR="Blue"] Someone also mentioned to me about a heater switch on the motor. Could this be the centrifugal switch?[/COLOR]
Yes, one of them is for the heater.
[COLOR="Blue"]
Or possibly a problem w/ the timer?[/COLOR]
Yes, Timer Switch 2 on the wiring diagram.
[COLOR="Blue"]I checked the cycling thermostat and is 0 ohms across the larger terminals and about 8 across the smaller terminals. Is that good?[/COLOR]
Yes
