signal
#1 Posted : Friday, September 21, 2012 7:24:23 AM(UTC)
signal
I'm new to this forum and need some help on where to go from here on my repair of the Whirlpool Quiet Partner IV.
Aside from the familiar blinking clean light, the symptoms are that the dishes are not as dry or hot as they had been before the blinking light first started. And the plastics are just plain wet.
There was still water in the bottom of the dishwasher, so I cleaned out the chopper and drain assembly. It was pretty clogged, but I still get the blinking clean light even after clearing the code. The blinking lights return about every fifth load but all the loads are the same with dishes that are a little wet and plastics that are very wet. They are also not hot, kind of warm.
The heater element has a small blister on it. Could it be as easy as replacing the heater element? I just don't want to throw parts at the dishwasher.
Thanks, George
#2 Posted : Saturday, September 22, 2012 8:39:26 AM(UTC)
Replacement parts for Whirlpool GU2700XTSY0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
See the attachment for the tech sheet
Yes it could.
Remove power from the unit and one wire from the heating element.
Then measure the element with a meter, should be between 10 and 30 ohms.
You may as well also check the high limit thermostat, it should be 0 ohms.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
GU2700.pdf (245kb) downloaded 5 time(s).
signal
#3 Posted : Saturday, September 22, 2012 10:38:46 AM(UTC)
signal
It was the heater element. All is hot and dry now. Thanks for your response to my question.
#4 Posted : Sunday, September 23, 2012 4:05:00 AM(UTC)
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
