sting_ray08884
#1 Posted : Saturday, January 8, 2011 8:22:42 AM(UTC)
sting_ray08884
The water dispenser doesn't work but the icemaker does. I get water out from the output of the filter. I have read this fridge has freezing problems, but cannot find the hose going to the door to be able to see if it is flowing there. I changed the filter already.
brad97
#2 Posted : Wednesday, September 19, 2012 3:44:46 PM(UTC)
brad97
the problem is that the ice dispenser flapper door was left a little bit open from ice sticking. This freezes the water dispenser tube. Try using a hair dryer to unthaw the tube. I also had to push a cable tie up the tube to break up the ice. If it freezes again use part of na ice cream stick and push it in on top of the water tube to act as an insulator. This works best long term.
Brad
