WilliamC
#1 Posted : Monday, September 17, 2012 7:05:28 PM(UTC)
WilliamC
My washer will spin on low but not on high. It doesn't want to fill with water either when on high spin. Is this a lid switch problem or something different. It seems to work fine when on low spin but sometimes even then it wont work. any help appreciated. Also this washer worked perfectly 5 years ago when put in storage just took it out of storage a week ago and noticed this problem.
WilliamC
#2 Posted : Wednesday, September 19, 2012 5:13:05 AM(UTC)
WilliamC
More info. I ran it though a few cycles last night and again when on low/(SPIN)low or high/(SPIN)low it worked correct but when put on a high spin cycle it filled then agitated for 15 seconds waited 2-3min. agitate 10-15 seconds waited 2-3 min then it added more water before the timer got to the rinse cycle then waited 2-3 min and sounded like pumping the water out but not spinning and then left 6 inches of water in the tub when it had completed its cycle I then put it on a low spine cycle and it spun the water out and these cycles last night were with no clothes in the washer.
Is there anything to rule out such as water pump, lid switch should they be ok since works on low spin. would this be the agitate switch or main switch or something such as motor or clutch.. thank you for any help
