jamieb2
#1 Posted : Tuesday, September 18, 2012 11:43:03 AM(UTC)
jamieb2
This is on its 6th year. Unit stopped during cycle and all lights and timer started flashing off and on. I run through test cycle and it stops at 4 but still no error code (E0).
For longest time I could get it going after up to a day and it run fine for a few days then start doing the same thing. I have not been able to get it going for last few days though. Just the flashing. I can get it to drain manually most of the time when I try pushing the drain key codes.
Help is needed in diagnosing the problem.
