Had a small leak on each side of the door, bought a new door gasket and installed now the leak is ten times worse. Is there some trick to installing new gasket? Pulled the kick panel at bottom to make sure of where the water was coming from, definitely the door vert edges.
Originally Posted by: rdstrhef  Had a small leak on each side of the door, bought a new door gasket and installed now the leak is ten times worse. Is there some trick to installing new gasket? Pulled the kick panel at bottom to make sure of where the water was coming from, definitely the door vert edges. Just removed the door seal that was newly installed a month ago and put it back in place. Started the washer and no leaks now. Can the seal be installed to deep in the track or is the seal not made correctly? Will I have to repeat this procedure every 3 or 4 washes? It seems to me that the more you open and close the door the seal will be pushed deeper with each closing. I'll keep you posted!
