5 Pages«<2345>
#31 Posted : Friday, September 14, 2012 3:01:30 PM(UTC)
What was wrong with the power?
stevehanna
#32 Posted : Friday, September 14, 2012 4:15:35 PM(UTC)
stevehanna
Breaker had tripped, and I hadn't realized. I had power on a separate line. Totally unrelated to this issue.
#33 Posted : Friday, September 14, 2012 4:27:48 PM(UTC)
Originally Posted by: stevehanna Go to Quoted Post
...absolutely dead on the rear righ simmer burner...
Have you replaced the potentiometer for this burner? If you have, then double check the connections.
stevehanna
#34 Posted : Friday, September 14, 2012 4:32:29 PM(UTC)
stevehanna
I did replace it. I will double check and make sure it is secure etc.
stevehanna
#35 Posted : Sunday, September 16, 2012 8:14:10 AM(UTC)
stevehanna
I don't breaker tripping was unrelated after all-clearly spoke too soon when I said unrelated- I thought once the front was working I was good...
I connected the line from the rear to the known good pot/valve- the breaker tripped immediately when I reconnected power (pot in off position). "Pop" and ozone. So generally un-good stuff.
At this point I am not sure what the best approach is? Is it to trouble shoot the wiring or is it better easier to just replace the wiring harness? Or is this likely even neccessary?
Anyway the funny thing is I was plugging the known good pot from the front into the rear connector. When I now examine the connectors I see discoloration on the front connector.
Any thoughts greatly apprciated.
#36 Posted : Tuesday, September 18, 2012 7:18:21 PM(UTC)
Check all wires for possible broken insulation. Double check the installation of all new parts.
stevehanna
#37 Posted : Monday, September 24, 2012 10:39:57 AM(UTC)
stevehanna
Hi Gene
I removed all connections and reseated them. Inspected all wiring and found no frayed bits, no bad insulation etc. All wires are nice and pliable etc. At this point I have installed new simmer control module, new spark module, and new pots on both simmer valves.
Reconnected everything and tested.
RESULT
Right burners ok and unchanged
Left front burner works in regular and simmer mode. Blue light lights, etc
Left rear burner does not work at all. No solenoid click, no blue light, no gas.
I swapped the solenoid from the front and rear burners on the off chance. The situation remains unchanged. Front simmer burner is perfect. Rear burner still dead.
Any recommendations on how to trouble shoot the rear burner?
#38 Posted : Monday, September 24, 2012 10:49:09 AM(UTC)
Repeat the troubleshooting as instructed in the attached file on the first page of this thread.
stevehanna
#39 Posted : Monday, September 24, 2012 11:00:04 AM(UTC)
stevehanna
That procedure is relevant to the PSC364GD? Remember I had the model number confused. If so I will get on it.
Steve
#40 Posted : Monday, September 24, 2012 11:21:20 AM(UTC)
Before you will do it, remove the potentiometer for the LR burner and accurately take it apart. Check the contacts inside. Very likely some of them are burned out. If that's true, replace the potentiometer.
- The potentiometer Part number: 422748
Part number: 422748
5 Pages«<2345>
