My dryer constantly flashes a E68 error code across the screen. When the door closes it comes on automatically. It does not stop running when I press the pause/cancel button and the only way it stops is when I open the door or unplug it. The start light blinds also but whenever I press the start button, a error code shows so it's not heating at all. What is the problem please?
Groups: APP Team
Joined: 2/12/2012(UTC) Views messages in topic : 5,556
Hi. The E68 code means that one of the keys (buttons) is stock closed. Carefully release the stocked key. If that doesn't help - replace the control board Part number: 134523200
