I put in a new rear drum bearing and when I place the drum back, it is rubbing on the front panel. The drum is slightly tilting down. Before I realized this problem, I completed putting the dryer back together. When I started the machinem there was an intermitting thumping. I took the front and top panels off and started the machine. This is how I discovered the rubbing. Can you help?
