dwolfe
#1 Posted : Tuesday, September 11, 2012 8:34:44 AM(UTC)
dwolfe
Need help in accessing the pump to see if it is clogged.
Simon / APP Team
#2 Posted : Tuesday, September 11, 2012 10:30:46 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Use the putty knife to open 2 clips on the top front corners, remove the front panel. The drain pump is on the right.
Locate the indicator light at the motor inverter board and check how many blinks there are.
Simon.
