muttonchop
#1 Posted : Monday, September 10, 2012 2:08:11 PM(UTC)
muttonchop
our timer wasn't advancing on our dryer (timed dry only, our dryer has no sensor), so i replaced it... it still wont advance, it just stays in the same place... any idea what's wrong? thanks for your help...
#2 Posted : Tuesday, September 11, 2012 1:45:00 AM(UTC)
Replacement parts for Whirlpool LER5636EQ3 ELECTRIC DRYER | AppliancePartsPros.com
I could not find one for an EQ3 so it is for an EQ2 but is probably the same as yours.
[COLOR="Blue"](timed dry only, our dryer has no sensor)[/COLOR]
Although your unit does not have a sensor it has auto modes which do sort of the same thing.
In a timed dry mode, the timer motor gets power directly through Timer Switch 0 contacts TM/WB.
In auto modes it gets power through the heating coil when the coil is shut off through Timer Switch contacts TM/OR. The 5000 ohm resistor is there to drop the 240 volts down to 120 volts so it does not blow the timer motor. There are a number of things that can cause it to not advance in auto re: a blown resistor, a grounded element etc.
So does it also not advance on a timed dry cycle?
File Attachment(s):
LER5636.pdf (240kb) downloaded 10 time(s).
