dhornman
#1 Posted : Wednesday, August 22, 2012 9:04:48 AM(UTC)
dhornman
After wash cycle, a small amount of water accumulates in the drum and increases as time goes by. I replaced the 3-way water valve AP4044218 and the problem still exists. Any other ideas?
Simon / APP Team
#2 Posted : Wednesday, August 22, 2012 12:39:19 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If you turn the water off at the faucet would the water level still rise?
Please provide the model and serial numbers.
Simon.
dhornman
#3 Posted : Thursday, August 23, 2012 6:43:16 AM(UTC)
dhornman
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Simon.
Have not tried that. Water level rises very slowly. There is maybe a cup of water in the drum after 24 hours. Less than before I changed the water valve. Model MAH9700AWW, Serial #16736269JC
Thanks, Dave.
Simon / APP Team
#4 Posted : Thursday, August 23, 2012 8:56:44 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
There is the chance that the hot water valve is
leaking Part number: 34001131
dhornman
#5 Posted : Monday, September 10, 2012 2:55:43 PM(UTC)
dhornman
Hi.
Besides the 3-way valve and the hot water valve, we now have a new problem, in the middle of the "normal" wash cycle we get an error message "nF" and the cycle won't continue. But, the "quick wash" cycle and "rinse and spin" will complete it's cycle.
dhornman
#6 Posted : Monday, September 10, 2012 3:04:13 PM(UTC)
dhornman
Besides the 3-way valve and hot water valve replacement, we have a new problem. In the middle of a "normal wash" cycle, the machine stops with an error code "nF". The machine works in the "quick wash" and "rinse & spin" cycles.
Simon / APP Team
#7 Posted : Monday, September 10, 2012 4:36:18 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check the water inlet hoses and screens inside them.The "nF" stands for no fill. The computer doesn't sense the water level rising for 12 min..If the water actually fills to a normal level, then check the water pressure switch, pressure hose, connections at the control board and sensor.
Simon.
