2 Pages12>
uvalaw
#1 Posted : Friday, June 19, 2009 2:48:36 AM(UTC)
uvalaw
My electric Kenmore Evenheat dryer intermittently wasn't producing any heat. Recently, it stopped heating altogether.
I tested all of the possible components with a multimeter per the tech sheet (including the temperature selector switch) and found that only the heating element didn't check out. Replaced that with a brand new part, but still no heat. Then I replaced all the other cheap & easy stuff (new thermal cut-off, new high limit thermostat, new thermistor, new thermal fuse), but still no heat. Then I replaced the more expensive stuff (new Evenheat control board, new motor because I thought maybe the actuator was faulty), but still no heat.
What else could possibly be wrong? The dryer runs fine, but just doesn't heat up. :confused:
#2 Posted : Friday, June 19, 2009 4:37:52 AM(UTC)
A Model Number may help other help you.
Could be a power problem.
If you loose half the line it can give a no heat condition as the heater requires 240 volts but everything else runs on 120.
Check the power at the plug with a meter, also check it at the terminal strip in the unit.
L1 to L2 = 240 volts
L1 to Neutral and L2 to Neutral = 120 volts
Note that sometimes loose connections can show voltage with no load but will open as soon as a load is applied. So if the volts measure OK with no load, I would check it at the terminal strip with the unit running. Just be careful as 240 is lethal.
Just remembered this so added it
http://www.applianceaid.com/whirlpool-dryers.html
see #40
uvalaw
#3 Posted : Saturday, June 20, 2009 4:26:37 AM(UTC)
uvalaw
good.
I just swapped the motor relay with the heater relay, since the motor was running fine before. Now the motor will only stay on if I hold the start button in and the heater element still isn't firing up when I'm doing that (i.e., holding the start button and letting the motor run).
Is this a definite sign that my problem is the relay? I'm figuring that if it was the relay (and I'm guessing that it was, since now the motor's not running on its own), then the heater element should still stay on as I'm forcing the motor to run. Or am I wrong?
I hope I'm wrong and that I've finally isolated it to the relay!
#4 Posted : Saturday, June 20, 2009 5:19:56 AM(UTC)
Here is the tech sheet
https://www.servicematters.com/d...0Sheet%20-%203979705.pdf
It does tell you that the heater relay is bad.
Am not sure if it is the only part that is bad.
They do not provide much info on what they are monitoring if anything, that would hold the heater relay coil power off.
It would be best to check the relay coil resistance to see if that is the cause of the relay not closing.
Also I would swap them back and see if the unit is now back to the original problem. If not, there is a possibility that the relay coil is shorted and this may have now blown the motor relay coil drive electronics.
If this is the case you will need a new board and a new relay.
Note: that you would have needed these before you did the swap, the board was already blown you just confirmed the cause.
#5 Posted : Saturday, June 20, 2009 5:41:17 AM(UTC)
It is very common for these Chinese made heater relays to literally blow out causing the pc board to burn out. You probably blew out the pc board if you left the old relay in!
#6 Posted : Saturday, June 20, 2009 5:46:59 AM(UTC)
uvalaw
#7 Posted : Saturday, June 20, 2009 7:31:13 AM(UTC)
uvalaw
resistance. Could it be that BOTH relays are bad? If so, then how would the motor still run normally?
I then did a live test with the dryer running in heated dry. The relay connected to the heater circuit showed 0vDC at the coil terminals and ~200vAC.
I'm not sure what this means exactly...
#8 Posted : Saturday, June 20, 2009 8:09:19 AM(UTC)
Cannot see both being bad as the motor was running correctly.
I assume the 200 was across the relay contacts.
The board is not telling the heater relay to close.
Run the diags in the tech sheet.
Check all the input devices to the board thermistor, dry sensor etc.
Also the START SENSE P1-5 on the board, this tells the board that the motor is running so it is OK to turn the heater on.
If all OK then by the process of elimination I would say the board is toast.
Chris Van
#9 Posted : Monday, September 10, 2012 4:38:22 AM(UTC)
Chris Van
Where are these relays located?
I simply did a search for the model number I am working on and came up with this thread.
I have replaced the heating element and the 2 switches located on the heating element housing.
Still no heat.
I'm no electrician so I'm not familiar with what relay does what on this thing.
Where do I go from here?
#10 Posted : Monday, September 10, 2012 5:30:00 AM(UTC)
See the attachment for the tech sheet as I do not think the link I included earlier still works.
Here are the parts
Replacement parts for Kenmore 11063942101 | AppliancePartsPros.com
Sears like to keep parts breakdowns in house but if you go to their parts site you can get the breakdowns. The relays are in the control console.
[COLOR="Blue"]Where do I go from here?[/COLOR]
I would check the power to the unit. If you do not have 240 volts everything will run except the heater.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
This may be a jod for a pro if you have no electrical experience!!
If the power is good then you will need a meter
I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
63942101.pdf (293kb) downloaded 6 time(s).
Guest (8)
2 Pages12>
