lather40
#1 Posted : Tuesday, April 7, 2009 7:31:31 AM(UTC)
lather40
Freezer freezes items but the refrigerator is not keeping items cold. Is there a way to check the condensor fan motor in the freezer or could it be something else?
woodchuckie
#2 Posted : Tuesday, April 7, 2009 8:06:39 AM(UTC)
woodchuckie
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's open.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
The fan in the freezer should be running when the compressor is with the door shut.
lather40
#3 Posted : Tuesday, April 7, 2009 8:29:00 AM(UTC)
lather40
Is there anyother way to check the fan motor in the freezer only place there was icing was inside the freezer when we went to pull out the fan motor. behind the panel on the right side of the coils
woodchuckie
#4 Posted : Tuesday, April 7, 2009 10:45:57 AM(UTC)
woodchuckie
If the fan is running it's ok. If not replace it. If there is lots of ice on the coils near the fan you probably have a defrost system problem.
Guest (4)
