theshadow92
#1 Posted : Monday, April 6, 2009 1:50:09 PM(UTC)
theshadow92
Recently, there are times where the refrigerator will work just fine. But from time to time, for the most part, temperatures will get warmer and there will be a humming noise. I was told that the humming noise came from the compressor and was a sign of a faulty relay and capacitor. Therefore, I went ahead and changed both parts. It worked great for a little but now the problem persists. If I turn it off for a little, it will start working again for a while. What gives?
#2 Posted : Tuesday, April 7, 2009 12:35:03 AM(UTC)
Here are the parts
Replacement parts for FRG FRS26HBBSB0 | AppliancePartsPros.com
Here is a tech sheet and a parts manual
ftp://ftp.electrolux-na.com/Pr...F/Anderson/240389607.pdf
ftp://ftp.electrolux-na.com/Pr.../Anderson/5995372132.pdf
Sounds like your compressor may be going.
A couple things to check:
1. Make sure the condenser coils are clean
2. Make sure the compressor/condenser fan is running
theshadow92
#3 Posted : Tuesday, April 7, 2009 7:10:47 AM(UTC)
theshadow92
I guess I forgot to mention that I've already taken both those steps. I highly doubt a compressor can go bad in around 7 years...I was thinking maybe it is a defrost problem?
#4 Posted : Tuesday, April 7, 2009 7:27:08 AM(UTC)
Turning it off for a little (depending on how much time a little is) will not solve a defrost problem. To fix a defrost you have to let the evaporator coils melt off the ice.
The simplest way to check for a defrost problem is pull the evaporator coil cover and look at the coil.
If it is heavily iced/frosted up then it is a defrost problem.
You may havea low freon problem. You can tell this often if the evaporator coils are just frosty where the freon enters the evaporator coils.
The following is a good link. Check out #20 re: the example pictures.
http://www.applianceaid.com/refrigerator.html
