Maytag microwave Mod UMC 5200 BAS lights up, turmntable works but doesn't heat.
Problem was failed connector on xfmr secondary; it holds 2 black wires. Small slip-on connector came loose from male spade; heat from probable arcing left residue on connector and spade. reconnected/soldered wires to connector; connector to spade and all OK.
Thank you; I will keep your contact information on file.
Jack Stevens, Bryan Texas
I'm glad you were able to fix it. Thank you for the feed back.
