Sparkey 3
#1 Posted : Wednesday, September 5, 2012 8:14:33 AM(UTC)
Sparkey 3
Amana , Bottom freezer not working. Cleaned coils , fan works , compressor not starting when temp turned up. any sugestions are appreciated thanks
#2 Posted : Thursday, September 6, 2012 3:12:41 AM(UTC)
Replacement parts for Amana ARB220RCW REF - BOTTOM MOUNTS | AppliancePartsPros.com
Since the condenser/compressor fan runs it is getting power.
You could check the compressor windings, see the following link.
How To Fix a Refrigerator - Appliance Repair Guide - ACME HOW TO.com
If the windings are OK you could try replacing the start device (PTC relay)
File Attachment(s):
ARB220.pdf (264kb) downloaded 4 time(s).
