joepasq
#1 Posted : Wednesday, September 5, 2012 9:26:14 PM(UTC)
joepasq
Unit won't start and I tested with multimeter all below as good:
1) 115vac outlet
2) door switch
3) push to start relay/switch
4) thermal fuse
5) timer
6) hotwired motor (blue and white) to 115Vac and motor ran and then gas unit fired up. Only ran it for a few minute but started right up and made no noises or hard start.
Only thing that I wasn't able to test is the electronic control circuit board, but not sure if that has anything to do with start up.
joepasq
#2 Posted : Friday, September 7, 2012 5:26:39 PM(UTC)
joepasq
Ended up being the power cord. Open in one feed wire inside the strain relief. Should have checked that right after the wall outlet but didn't.
