I just replaced the outer door glass due to a moving mishap and the first time i run the washer after fixing it the door seems to leak. after further inspection there is water between the back door support and the new outer glass. when i feel around the inner door glass the seal between it and the back door support is not water tight at the bottom. do i need to take it out and silicone around it or is there something i am missing?
