2 Pages<12
ellwood1
#11 Posted : Wednesday, September 5, 2012 5:07:27 AM(UTC)
ellwood1
I'm sorry, I have indeed sen the previously posted info, but here is my real problem. I know where the chopper is but I cannot get to it as I am afraid to break something.
I can remove 3 of the 4 screws on the pump cover/screen but I cannot seem to move the feed tube from the inlet valve. there is not enough room to remove it from just unclipping the first top clip. It cannot move to the 2 oc position while still attached.
You also mentioned that the water feed tube can be removed from the upper clips on the back wall. Are they the small metal on each side halfway up on either sid on the round fitting that the upper spray arm enters when the top tray is rolled back? It just seems that this is an awful lot of parts that have to come off to access a screw and a cover.
I do really appreciate your help but the cure seems so easy if I can just get past these assemblies...
#12 Posted : Wednesday, September 5, 2012 6:33:30 AM(UTC)
I have never taken a unit apart that has the manifold at the back.
A far as I know the rear feed tube (Item 2 in Section 7) should un-clip from the feed tube (Item 12 in Section 2) so you can remove it
Perhaps clicking on the different parts pictures will help as there is often more views ans a Q&A about that part.
kitchenaid owner
#13 Posted : Wednesday, April 10, 2013 5:51:34 PM(UTC)
kitchenaid owner
I am having the exact same problem with a 13 month old Kitchen Aid Model #Kudc10fxss. Did you find a solution?
2 Pages<12
