localboy9183
#1 Posted : Tuesday, September 4, 2012 9:49:29 AM(UTC)
localboy9183
Hi!
Hope you can help me. The left rear burner does not spark or "tick" when I turn it on. I also replaced the igniter with no luck. Gas is flowing. It will ignite with a lighter. It does not "tick" when the other burners are turned on. I need to know which part I need to order to fix the problem. Can you please help?
Simon / APP Team
#2 Posted : Tuesday, September 4, 2012 2:36:10 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Switch around HV igniters wires and check if that makes any difference.
You may need to replace the HV wire or the spark module.
The module Part number: WB13K25
localboy9183
#3 Posted : Tuesday, September 4, 2012 7:15:24 PM(UTC)
localboy9183
Thanks for the quick reply. I'll try switching the HV igniters to see if the "dead" burner ticks. I wasn't sure if I should replace the module or the individual valve. I'll let you know what happens.:o
Simon / APP Team
#4 Posted : Tuesday, September 4, 2012 9:31:06 PM(UTC)
Simon / APP Team
Groups: APP Team
Don't switch the ignitors, only the wires.
Simon.
localboy9183
#5 Posted : Thursday, September 6, 2012 2:12:17 PM(UTC)
localboy9183
Hi again, Simon!
I was unable to switch the HV igniter wires since they are custom-cut to the length to reach each burner. I am ordering a wire harness, since it appears the switch for the left rear burner won't "click." Gas flows, but no ignition. I'm hoping replacing the switch wire assembly will solve the problem
Simon / APP Team
#6 Posted : Thursday, September 6, 2012 2:27:21 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Try to switch the wires at the spark module.
Simon.
