Dryer stopped its cycle but will not start again. No noices coming from anywhere on machine?????
Groups: APP Team
Hi. First of all check if there 240VAC at the wall outlet. Next check the door switch, next the thermal fuse located at the back on the blower housing.If the fuse is blown - clean the entire exhaust system. The thermal fuse Part number: 3392519
Originally Posted by: Simon / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi. First of all check if there 240VAC at the wall outlet. Next check the door switch, next the thermal fuse located at the back on the blower housing.If the fuse is blown - clean the entire exhaust system. The thermal fuse Part number: 3392519
Thanks Simon will do just that..... Pilsner
Groups: APP Team
Originally Posted by: Simon / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Keep us posted.
Simon.[/Everything you said was right on. It was the thermal fuse so thanks a million you saved us a bunch of money on the repair job. And we ordered it though the company.
Ed and Sue
Groups: APP Team
You are welcome.
Don't forget to clean the exhaust.
Simon.
