Found the diagram, handle #, and rec'd part. The trim piece was removed. Only one screw is exposed on either end of the handle. I cannot get to the second handle screw on either end. Please help me to move on to another project!
The inner frame has 8 tabs: 3 ea on top/bottom & 2 ea ends. With flat /regular end screw driver release tabs at far side of hinged end. Work around inner frame. Remove. The 2 screws now are visible. You need the small tiped phillips screwdriver to remove.
