Beaver81
#1 Posted : Thursday, August 30, 2012 12:44:36 PM(UTC)
Beaver81
Range had error msg 'F1' and called sears repairman. He troubleshot to membrane switch that was discontinued. I found switch online and replaced but now the clock just blinks and the touchpad does not respond when touched, no corresponding 'beep' and i cannot access the oven controls. The cooktop elements and fan work fine. I checked the ribbon and it is plugged firmly into the control board, what else should I be looking for?
#2 Posted : Thursday, August 30, 2012 3:00:51 PM(UTC)
If you are sure that the new membrane switch is good then the problem is a bad control board (aka timer).
- The control board Part number: Y04100262
Beaver81
#3 Posted : Friday, August 31, 2012 4:56:30 AM(UTC)
Beaver81
We replaced the control board 2 yeads ago. How can we test to make sure the membrane switch is good?
#4 Posted : Wednesday, September 5, 2012 3:23:04 PM(UTC)
Sorry for the delay.
Unfortunately there are no any reliable instrumental tests for the membrane switch.
