kgates123
#1 Posted : Thursday, August 30, 2012 11:49:19 AM(UTC)
kgates123
my dishwasher is not drying and dishes are still wet even after letting them sit overnight. I tested the heating element (15 ohms) and it is good. what is my next step?
#2 Posted : Thursday, August 30, 2012 3:41:09 PM(UTC)
Locate the turbidity sensor (#321 at the diagram). Check for continuity between the pins 1 & 4. If there is no continuity, the sensor has to be replaced. Unfortunately this part is no longer available.
If the reading is correct, replace the control board.
- The control board Part number: WD21X10215
rossupshaw
#3 Posted : Thursday, June 26, 2014 6:31:02 PM(UTC)
rossupshaw
Gene- Does this turbidity sensor have anything to do with the drying cycle. I see that it senses the dirtiness of the water, but that is not my problem. They are clean, just not dry.
Guest (4)
