kapittma
#1 Posted : Tuesday, August 28, 2012 9:20:45 AM(UTC)
kapittma
The bake ignitor in the oven will not turn on. Gas range and broiler work just fine. I replaced the bake ignitor as this seemed like the obvious problem, however it still doesn't work. No glow on the brand new bake ignitor either, so of course no gas. Curses.
I was very careful with the ignitor (both new and old) and neither appears cracked or damaged. What is going on? Any ideas?
Thanks kindly for any advice!
kp
kapittma
#2 Posted : Wednesday, August 29, 2012 10:10:07 AM(UTC)
kapittma
kp
Bump. Anybody?
Simon / APP Team
#3 Posted : Wednesday, August 29, 2012 10:28:50 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Get access to the control board, set the oven for bake and
using the multimeter check for 120VAC between BAKE and N.
If no voltage - replace the control board.
If there is 120VAC - trace the wires down to the safety gas valve.
Turn the oven off and check the valve for continuity with one wire off. If it's open - replace it.
The clock Part number: 12001627
The valve Part number: 74006427
Here are the breakdown diagrams and Replacement parts for Maytag MGR5750ADW RANGE- S/C F/S GAS | AppliancePartsPros.com
Thank you. Post the results.
Simon.
kapittma
#4 Posted : Monday, September 10, 2012 5:37:32 PM(UTC)
kapittma
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Simon.
Thanks for the info. I indeed checked the panel and I get 119.6V between Bake (Red wire; "BA" on panel) and N (white wire on back of panel). I'm assuming that means it is fine. You suggested checking the gas safety valve for continuity, which I have yet to do. However, if there was an issue with the gas valve, would this not shut off the gas to the broiler as well as the oven?
I did check the old igniter that I thought was the issue and it turns out one of the wires under the insulation was broken, so I'm really surprise the new one won't work. Not only that, I switched the broiler igniter (which works fine) and put it on the bake element, and it doesn't work either. Something else is going on.
I just find it so weird that there appear to be two simultaneous issues happening here at the same time. I am so confused.
Guess I better check that gas valve!
Thanks kindly for your help.
kap
Simon / APP Team
#5 Posted : Tuesday, September 11, 2012 8:20:56 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You have there a dual gas valve - separate coils for bake and broil. Check the bake one.
Simon.
Guest (4)
Maytag oven problem (Oven Repair (including Ranges and Cooktops))
by hoof140 11/23/2010 10:01:05 AM(UTC)
Maytag Oven Problem (Oven Repair (including Ranges and Cooktops))
by FI62 8/3/2009 9:13:05 AM(UTC)
Maytag Oven problems (Oven Repair (including Ranges and Cooktops))
by kevinw3 6/15/2009 12:04:33 PM(UTC)
