tkent29
#1 Posted : Sunday, August 26, 2012 6:32:33 AM(UTC)
tkent29
My washer will no longer spin. The water drains but doesn't do the spin. Thought I smelled rubber when ran the last time. Can you tell me what might be wrong and how to fix?
sidfink43
#2 Posted : Tuesday, August 28, 2012 5:06:31 PM(UTC)
sidfink43
If it will still agitate then I think the problem is with the clutch and brakes. Use your model number to go the parts diagrams and you will find the clutch parts along with a video on how to change it out.
Also see the Sticky by Richappy on direct drive brakes at the top of the main washer page. It's good stuff.
Estate Washer wont spin, not the coupling (Washer Repair)
by Greenday1827 2/28/2014 3:55:12 PM(UTC)
whirlpool estate washer wont spinout water (Washer Repair)
by itsmelatricia 2/14/2010 6:58:03 PM(UTC)
