RandyMc
#1 Posted : Friday, August 24, 2012 8:47:48 AM(UTC)
RandyMc
Hello-
It is a 2010 stainless steel Whirlpool Frig. with bottom freezer and dispenser-Model # GI5FSAXVY02. The touch pad keys are not working in three functions: #1-the water dispenser key will not activate when pushed. #2-the frig. temp. control-arrow up-key will not increase temp., but will lower temp. #3-the dispenser light key doesn't function when pushed. Checking which part may be required for these malfunctions?
Thanks-Randy
Simon / APP Team
#2 Posted : Friday, August 24, 2012 10:35:08 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Disassemble the dispenser, remove the ribbon connector from the control board and clean it with isopropyl alcohol or the pencil eraser. If that doesn't help - replace the overlay pad Part number: W10315980
Here are the breakdown diagrams and Replacement parts for Whirlpool GI5FSAXVY02 REFRIGERATOR | AppliancePartsPros.com
Thank you. Post the results.
Simon.
RandyMc
#3 Posted : Friday, August 24, 2012 10:57:28 AM(UTC)
RandyMc
Thank you, sorry for my question. Can you inform me the safest way to remove the dispenser panel and once I get it off is the ribbon easy to find to clean or can you describe it?
Again thanks, Randy
Simon / APP Team
#4 Posted : Friday, August 24, 2012 12:25:26 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Take the drip tray out, remove two screws and you should be able to take the frame out. The ribbon connector is behind the frame. Unplug the unit just in case.
Simon.
RandyMc
#5 Posted : Friday, August 24, 2012 1:04:33 PM(UTC)
RandyMc
Simon, do I clean both, the ribbon connector and control board or just the ribbon connecter with alcohol?
Simon / APP Team
#6 Posted : Friday, August 24, 2012 1:09:05 PM(UTC)
Simon / APP Team
Groups: APP Team
If you will clean the control board make sure that it's completely dry before plugging it in.
Simon.
