Chuck Porter
#1 Posted : Friday, August 24, 2012 12:30:34 PM(UTC)
Chuck Porter
:confused:Replaced water inlet valve (part number WPL 2315576). Getting water with good pressure to the valve. No water passing through valve. Getting good continuity check form valve. Questions. Which way does the harness plug into the valve? It will plug on either way. Not getting any water through the valve to ice maker. What is my next step?
Simon / APP Team
#2 Posted : Friday, August 24, 2012 1:19:39 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You can put the plug on either way. Check if the inlet tube into the icemaker not frozen. Defrost it if needed.
If it's not - replace the icemaker Part number: 4317943
Here are the breakdown diagrams and Replacement parts for Roper RT21LMXKQ04 REFRIGERATOR | AppliancePartsPros.com
Thank you. Post the results.
Simon.
