lexusnip
#1 Posted : 13 years ago
lexusnip
I thought a couple drum rollers might fix the horrendous squeek coming from my dryer but after replacing them I am looking elswhere. The belt appears to me a little worn as a few strands are coming loose but with a flashlight im guessing the tensioner pulley might be the real problem. Or possible a bearing somewhere. Any ideas??
Simon / APP Team
#2 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Hi.
Most likely it's the idler pulley and the shaft.Check if you need both , then order pulley and arm.
The other possibility is motor bearings.
Here is the breakdown diagram Motor drive replacement parts for Maytag MDE9316AYW DRYER- ELE | AppliancePartsPros.com
Thank you. Post the results.
Simon.
Squeeky dryer (Dryer Repair)
by julieshaver@bellsouth.net 13 years ago
ear piercing squeeky dryer!!! Help! (Dryer Repair)
by fawn_eyes888 15 years ago
Squeeky Dryer (Dryer Repair)
by tbela 15 years ago
squeeky dryer (Dryer Repair)
by shorembo 15 years ago
by jooey2 15 years ago
by Stonehenge 15 years ago
by Squeeky Dryer 16 years ago
by clayandlin 16 years ago
