jjlittle.64
#1 Posted : Thursday, August 23, 2012 7:57:17 PM(UTC)
jjlittle.64
Kenmore front loading washer. Same as a Duet. The washer will fill with water. The motor will slowly move the drum when empty, but would only nudge the drum when full. The motor never goes to a high speed spin. The motor (or possibly a relay somewhere near the motor) makes a clicking noise. When it is slow spinning. After about a minute, the whole thing shuts down. When I restart the washer and start the rinse cycle again, it pumps out the water just fine and starts to fill it up again. I have taken the back off and inspected the belt and pulley. They are fine. The drum free spins fine. I,m guessing the MCU, possibly the motor. If the motor was bad, would it just not turn at all? Any help would be appreciated.
jjlittle.64
#2 Posted : Thursday, August 23, 2012 11:00:22 PM(UTC)
jjlittle.64
Also. I do not get any type of error code. It just shuts down.
