Gary Whitis
#1 Posted : Monday, April 6, 2009 7:53:08 AM(UTC)
Gary Whitis
I Have A Side By Side That Has Water Despenser And Ice Maker. The Water Dispenser Is Working Fine But I Am Not Getting Water To The Ice Maker. I Am Getting Water To Valve And Have Taken It Off And All Looks Fine. But Getting No Water From Valve To Ice Maker.
woodchuckie
#2 Posted : Monday, April 6, 2009 7:59:02 AM(UTC)
woodchuckie
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The ice maker may not be sending for water.
Gary Whitis
#3 Posted : Monday, April 6, 2009 8:53:32 AM(UTC)
Gary Whitis
I tried swapping wires and got no water on either. Put wires back and got water from water dispenser but still none for ice maker
woodchuckie
#4 Posted : Monday, April 6, 2009 12:55:46 PM(UTC)
woodchuckie
That sounds like the valve for the ice maker is bad.
ice maker is not getting water (Refrigerator & Freezer Repair)
by johnstrohecker 7/27/2009 2:34:56 PM(UTC)
