No lights on at all unless i press hi temp them heated dry then normal wash and start. It will start quick rinse then normal wash will start soap door opens goes back to quick rinse then back to normal then off all in about 2-3 mins. I have turned breaker off and left off for 10mins, also undid ribbon and turned on motor started put all back toghter and still same thing any ideas please!!:confused:
Groups: APP Team
Hi. Based on what you are describing most likely it's the control panel. Part number is Part number: W10137549
Thank you. post the results. Simon.
Originally Posted by: Simon / APP Team  Hi. Based on what you are describing most likely it's the control panel. Part number is Part number: W10137549
Thank you. post the results. Simon. Thanks for a fast response. Is there any test or anything I can do to test the control panel to ensure thats it?
Groups: APP Team
Hi.
Remove the toe panel and locate the tech sheet. Hopefully it will have the touch pad test. Also, you can pull out from the control board plug the flex ribbon connector and clean the edge with isopropyl alcohol and /or pencil eraser.
Simon.
