cnw126
#1 Posted : Wednesday, August 22, 2012 1:45:42 PM(UTC)
cnw126
Hello Everyone,
I have a Whirlpool WFW9250WW00 washer that will not work with hot or warm water. If I attempt to do a load with hot/warm no water enters the washer and I eventually get a LF error. The washer works fine with cold water.
I have so far replaced the hot water inlet valve and the pressure switch. I am also sure that I am getting plenty of hot water to the valve. I still have the same problem.
I tested the continuity of the wire going from the computer to the water inlet valve and the wire is good.
I don't want to just keep throwing parts at this thing.
Is there a way that I can do some tests or something so that I can figure out what is wrong? Any advise would be most appreciated.
Simon / APP Team
#2 Posted : Wednesday, August 22, 2012 5:01:35 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Locate the plug VCH7 at the CCU and check the resistance between the pins 5-7. If you read about 800 ohms replace the CCU Part number: W10299981
cnw126
#3 Posted : Thursday, August 23, 2012 7:49:09 AM(UTC)
cnw126
Hello Simon,
I located the VCH7 plug.
I checked the resistance on the plug between 5-7 pins and got a reading of 800 ohms. So, according to your instructions I should replace the CCU.
However, I am confused because I also checked the resistance on the computer and got a reading of zero ohms.
Maybe I am not thinking about this correctly but it seems to me that I should be checking the resistance on the CCU if I am trying to determine if the CCU has a problem.
In addition, it seems to me that the D16 plug on the CCU controls the hot water inlet valve. Should I be checking the computer and or plug at D16?
The wire going from the valve to the D16 plug is showing zero resistance, so it is good.
I sincerely appreciate the help but I do not want to order a $160.00 part unless I am sure it is what I need.
Thanks,
Chad
Simon / APP Team
#4 Posted : Thursday, August 23, 2012 9:01:53 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If you get the part from APP you can return it even if it's been installed.
Replace the CCU. Post the results.
Simon.
cnw126
#5 Posted : Saturday, August 25, 2012 12:30:45 PM(UTC)
cnw126
Hello Simon,
I replaced the CCU and the washer works!!!
Thank you for the help.
Chad
Simon / APP Team
#6 Posted : Monday, August 27, 2012 11:09:38 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
