dbagel
#1 Posted : Monday, August 20, 2012 4:59:04 PM(UTC)
dbagel
replaced motor. Have a e-12 code. Drier will only run for 3-5 secs. Same problem as before replacing motor. Please help!
#2 Posted : Tuesday, August 21, 2012 6:07:14 PM(UTC)
Most likely the problem is a bad main power board. If you need the correct part number, verify and repost the model number because it does not come up.
